Root Netflix work around
MCPO117
I found this posted online. I tried the HTC Vision and it still said device not supported so I'm trying the nexus s version right now. Please post if you get it to work and which one you used.
[ROOT] How to edit your build.prop to make Netflix work on unsupported devices : Android
Edit: Ok i tried changing the device name to both the HTC Vision and the Nexus S no dice on either one. But I noticed it still has mecha listed in other places right by these lines we're supposed to change. I don't know enough about build props so I don't want to go mucking about and screw something up. Anyone out there with a little more technical knowledge want to take a look and see if we can figure this one out?
