A arkwright Member Feb 28, 2011 #1 Hi All I'm looking for a way to toggle my mobile network on and off from my homescreen. Any ideas? Many thanks Arkie
dorsetsav Well-Known Member Feb 28, 2011 #2 I would recommend Elixir. It does a lot more than just toggle APN on and off, but is very customisable from a homescreen widget point of view.
D Deleted User Guest Feb 28, 2011 #3 There is a widget that comes with the desire. Long press screen, widget, settings, mobile network. That's what I use.
B BurnCK Well-Known Member Feb 28, 2011 #4 Beautiful Widgets (worth the purchase) also comes with Toggle buttons for Wi-fi, 3G, etc,.
B biffsmash Well-Known Member Feb 28, 2011 #5 Widgetzoid is really good and has almost every widget you need, for network, sound, screen, etc.
F firedesire Well-Known Member Feb 28, 2011 #6 dorsetsav said: I would recommend Elixir. It does a lot more than just toggle APN on and off, but is very customisable from a homescreen widget point of view. Click to expand... +1 for Elixir
