Help Network Errors & Weirdness
knitpurlgurl
I got a msg on my phone that the SD card may be damaged and that I needed to format it. So I did. Then I flashed a ROM (GSB + gapps) and rebooted. Now, everytime I try to access the Market, I get a "Network Error - Retry or Cancel" msg. Someone suggested I pull the battery and then go from there. I did and I'm still getting the same network error. Did I brick my phone?
Update: Installing Eris Market Fix via Android Market Online.. Going to see if that works.
Update: Eris Market Fixed installed; rebooted; continuing to get Network Error msg
Update: Updated Roaming Capabilities just for giggles.
Any chance that you can checks what happens when you try to access over WiFi? If you Nandroid restore an older ROM, does the market work there?
I disabled the WiFi, re-flashed the ROM and gapps and all is well. Must have been my WiFi.
