Network-heads, help us optimize!
Blanco720
So many of us do not have unlimited data or prefer to use wifi for the speed boost when available. At home, we have the option to alter our router's firmware settings which could potentially bring super fast speeds to our phones.
So any of you guys with networking knowledge, please share your router settings with the forum so that we might all take advantage of the fastest speeds on our Inspire!
What settings are you exactly looking for? I get about 17500kpbs using speedtest when connected to my home router. I have a "N" router with some custom settings but nothing crazy. If someone could enhance that with some setting that would be great.
I have no idea what my router should be set at to ensure that its emitting the strongest single with the least ammount of security (as I have heard the more encryption, the slower it will go). Im curious what people who had modified their firmware settings have done and how it will effect data speeds.
This may be true but I do not think it makes that much difference. Usually the distance from you to the router is more important. Stand right next to it and see 50mb, stand 1 floor down and in a corner and you will see 3mb.
Security is more important than speed IMHO. Also I am not sure what the Inspire can handle (N or G) but that can limit speed as well.
I have a 100 MB line with my cable company and yet I am only seeing 17MB on my phone 1 floor down from the router. I will try closer to the router when i get home tonight but I dont expect much difference.
Im only getting 12 on my Inspire while sitting in the same room so something is messed up. Can anyone help?
My Wifi-to-Inspire speed at home has been less than optimal. My laptop normally connects to my N+ router around 115 Mb/s.
My Inspire connected at 55 Mb/s while standing in the same location as my laptop. I placed the Inspire within a foot of the router, and my speed only increased to 65 Mb/s.
FYI: for testing WiFi speed, don't run internet speed tests. Go to your connected networks, and select your connected network. It will display the WiFi connection speed. Your true internet speed depends on your ISP.
jesus what is your router set at that you can pull down 55 mb/s? like I said, im only getting 12. maybe ill do a factory restore of the router or something. thats SOOO much faster than what im getting.
Just some insight. You cannot compare your laptop's WiFi performance to your Inspire's WiFi performance. Laptops WiFi chipsets are built with larger antennas, more powerful processors, etc. They will in all circumstances clearly outperform your Inspire because smartphone WiFi chipsets have to meet a tight power/RF requirements.
Also, there is no point in trying to attain super-high WiFi speeds because at some point, the bottleneck is going to be your phones processor and RAM. For most current smartphones, you'll probably top out at 30-35Mbps actual sustained data transfer speeds.
Thanks. Taking that information into consideration, my speeds are excellent.
You may have interference with other routers in the area. You may need to change the router's channel.
Try this product for choosing an optimal WiFi channel.
inSSIDer | MetaGeek
On your Inspire, does the WiFi icon show full signal strength?
There ARE priority settings on mine. Example I madr video streaming the highest priority on mine to stop the lag when streaming netflix and it worked. There is also one for gaming. Not sure if one of those would help phone users though.
inSSIDer | MetaGeek
Yes I have excellent signal strength. Maybe I am overplaying the importance of solid router settings in terms of data speeds, but as was previously mentioned, a speed of even 20, let alone 30+ is simply not happening for me.
I read that if you set the band to one and not dual or multiple, this helps.
I'm assuming you have at minimum, a wireless G router. I would go into router config, save the config, and then reset the router to factory config. Experiment from there. If problems continue, then I would consult a forum specific to the make and model of your router. Good luck.
