Help Network scan error
DiePolle
Hi all,
I have a problem with my Flytouch 3.
Last Friday everything was fine but now, when turn on Wi-Fi, I receive the message "Unable to scan for networks".
Installed ROM: Tim-V4 *Version 4d* (before 4c/3d)
Edit: Solved
I am having the same problem, I cannot get my WIFI to scan properly. It happened after loading the newest software from the Merimobile site. I don't see any way to go back to the older firmware so I need directions if I can get them from anybody else.
I have not received mine in the mail yet, but can't you do a factory restore? Then go back to the version you liked.
I just installed tim4e on mine, and now have the "unable to scan for networks" message and can only connect with an eth cable.
