Root Neural network
Dysnomia
Hello, first off I'm running the ultimate droid 2.5.0 on my droid, and I'm looking for a way to install the original neural network from the stock live wallpapers, the customizable one that comes with the rom just doesnt look or feel the same. Any help would be appreciated.
Download this
Included are:
  • original neural network (full colors, not verizon version)
  • gingerbread live wallpaper (cause its awesome)
  • script to change lwp (thanks to bb v.5)
Here's what you do:
  1. Make sure you have BusyBox installed as you need it to run the switchlwp script
  2. Move the 'switchlwp' script and the desired LWP to the ROOT of your SD Card
  3. Make absolutely sure the LWP is named LiveWallpapers.apk
  4. Use Terminal Emulator (or equivalent) and type
    Code:
    su
  5. You should now receive superuser prompt, accept and you will see a '#' indicating root access
  6. type
    Code:
    sh sdcard/switchlwp
You should now have a new LWP! note:you may need to select it from the LWP selector - also i am running UD 2.4 but it should work for 2.5 as well.
