Help New 32gb (need help)
Yeah... if you have enough space on your phone you can use a file explorer to move sd card contents to a new folder in /data (dummy folder) and swap memory cards.
Move the contents of your old sd back to the new sd and delete your dummy folder.
If you don't have enough free room on the phone memory you can leave the folder and swap files back and forth if you really need to.
You can also use a wifi file explorer and another android to transfer via wifi all at once.
Or blietooth.
Out of ideas...
Edit****
IDEA!!!!!
if you are doing the dummy folder thing you can temporarily dump any media files (ringtones, wallpapers, alarms, boot animation files and the like) that aren't vital at the moment (current ringer and notification sound) on the larger sd card to free phone space for the dummy folder.
