Psychopaths
Hello everyone.
I am new to the forum and new to rooting. These are the steps I have taken towards rooting my phone:
1. I had my Esteem updated to "ZVC", so I followed the guide found here in order to downgrade to "ZVB."
http://androidforums.com/esteem-all...ed-zvc-wants-root-back-confirmed-working.html
2. Then, I proceeded to root my phone with the "One Click Root" method.
http://androidforums.com/esteem-all-things-root/426160-one-click-root-now-available.html
Questions:
1. In order to remove bloatware, I read that I need to use "Root Explorer." Where is that located? If it's an app, then I don't think I have it.
In fact, the only thing that has changed with my phone was that there was a new app called "Superuser" installed. EVERYTHING is basically the same. (All apps, settings, themes, etc are still on the phone after downgrading and "rooting." Not sure if this is normal.)
2. In the "One Click Root" thread, the last post states that:
3. After I have successfully rooted my phone, what are the next recommended steps in order to maintain the best possible security and stability I can take? I'm talking about backups, performance, etc.
Sorry for the wall of text guys; I hope you guys can answer my questions.
Questions:
Does this mean that this method is no longer working or recommended? Is the "Root & Recovery" sticky the new way to root? I am so confused.This can be removed from sticky as it is no longer needed with root and recovery install
