Hello all I am looking to buy a new Battery for my droid 2 I do Not want the extended Battery that will make the phone thicker but is there a better Battery than the stock one ?
Thanks ..
BTW, if you use a case, that case might already be making your phone thick enough to accommodate the larger battery. Mine does, so with the stock battery mine just has extra space inside the case.
