new battery?
GamingForever
I'm thinking of getting a new battery and the one in my phone is 1600 mAh but the one i see on amazon is 1500 mAh.. is there a difference between the two.. will the 1500 last longer or die out quicker?
Gamingforever the stock battery is 1600mAh the one you saw was 1500mAh meaning it has less juice i can personally tell you an extended battery will go a long way :D i have purchased two 3800mAh extended batteries and in 6 hours i only lose about 20-30 percent battery
hope that helps :D
I just looked at the site and yes that definitely an error a 4200mAh extended battery will far surpass those specs the give for it
But a typing error to me is ok as long as i get the battery i paid for. Haha i should call them and tell them they fucled up and sent me a stock batery without a back and send them my old one while theu refund me. Wish that would work
You're awesome.
Let us know the battery life on that monster when you get it and it settles.
But either way, I would at least try.
Ill keep you guys updated when it arives and iv cycled its life once and ya im still gunna try and have them buy back my old bat that way cuz i wont need it
Guys, you didn't tell me that the battery is huge and makes my phone weight 3 times more than it does... I'm not liking this...
I'm going to return the battery... The phone was heavy enough. :(
Dude what did you expect for a bat thats 3x the power? It should have had pics for you to see and theres another entire thread that woulda told u it was huge lol
I take it you did not see my post Dated July 22nd,
http://androidforums.com/zte-warp/556622-aftermarket-extended-battery-recieved.html
I felt the same way.I returned mine the next day for a refund and picked up two stranded replacement batteries along with a wall/usb charger and i could not be happier.If i am heading out for a hike,run or bike ride and will be using the gps on Endomondo Sports Tracker along with my Bluetooth stereo headphones then i just toss one or both in my backpack,saddle bag or armband case and im good for the day this way its still sleek and comfortable and its not looking like some old outdated device,I knew as soon as i received it that it would not fit in my armband case and be to bulky to fit in my handle bar mounting bracket so that was the deal breaker.Its a good concept just not functional for my life style.
