Help New EVO 10/2, text msg problems
I just bought a new EVO yesterday, and the CSR transferred the old txt msgs as well as contacts from my Lotus to the EVO.
This morning at ~7AM the EVO started re-sending 'all' the old texts, at least 3 weeks worth. I was playing with the phone at the time, and thought that it might have been operator error, but it just started doing it again on Sun ~7PM.
An info msg pops up to the effect that 'you sure are sending a lot of SMS msgs all at once, do you want to continue?', but it's per message.
Any idea how / why this started, and how to stop it?
Thanks!
Thx, sitlet. Are you suggesting the battery pull to simply stop the msgs when/if it starts again, or as a 'cure'?
I did turn off the phone several times and let it sit for 20-30 min. All was OK until ~12 hrs later when it started sending the txts again.
I'd try a battery pull as a "cure"... if that doesn't work I'd do a hard reset.
Goodness, Android seems to have quite a few annoying text message bugs.
The rep shouldnt have transferred your texts to begin with. Going from a non android phone to an android phone can cause problems like that. If that doesnt work, I would just suggest deleting all the texts and start from scratch.
@sitlet, he asked if I wanted them transferred and I said 'yes'. Thought it was a good idea at the time...
@unwallflower - I ended up deleting all the msgs this AM when it started again.
