I am getting a nook in the mail today. I assume it will have V1.2. I did some research and below is my understanding, I would really appreciate it if any of your veterans can look over it and let me know if I am understanding this or if I have my steps wrong. I winged it rooting a droidx and really wish I had a clear understanding before starting that project.
1. I assumed before I do anything, I need to root using Autonooter but it says I cannot use with v 1.2 which I assume my nook will come with. So I need to use Manual Nooter? Link below
ManualNooter 4.5.25 (For Stock 1.2) - xda-developers
2. Now I will need to repartition using the link below?
[HOW-TO] Repartitioning the NC back to 1GB/data, 5GB/media - xda-developers
3. Only then can I install Phiremod to the internal memory using this link?
http://androidforums.com/nookcolor-...emod-your-nook-color-updated-5-29-2011-a.html
4. Then I can install Honeycomb on the SD card using the below link (I bought one of those Sandisk C2 8GB cards from RadioShack)
http://androidforums.com/nookcolor-...eycomb-android-3-0-nook-color-usd-method.html
Can I assume I can install customer Kernels using clockwork in order to overclock any time after step 1?
