Pinmac1
I'm edging ever closer to my current contract ending and getting my Galaxy Note. I have been following threads on here with interest. I assume that it will not have ICS pre-installed yet so will need to do it myself. There has been some discussion about factory resets helping to set the Note up well.
Is it worth, before installing any apps/data, doing a factory reset on Gingerbread before I upgrade to ICS and then doing a second factory reset? Or will that put it back to Gingerbread? Will I even get the choice to do a factory reset on Gingerbread or will I be offered the ICS update as soon as I turn it on? Can you tell I'm a bit confused?
Also, I currently have an HTC Desire and all updates have been OTA. How does the upgrade to ICS work? I keep seeing Kies/Kies Air mentioned.
So many questions and I haven't even got the Note yet
. Thanks for any help.
