Root New OTA issues
palmtree5
Sunny Vacation Supporter!
Moderator
Received a notification about a new OTA and attempted to update (which failed, of course) So I used this app and am posting the output here.
[HIGH]================== Detailed Analysis ==================
- you have 6 frozen system apps; this may (but not necessarily) impact the ability of
the OTA's updater-script to update these apps and cause the OTA install to fail
- there were 3 failed expressions; see below
for the details about these tests that will cause your OTA install to fail
- there were no bypassed expressions (good!)
Frozen system apps analysis:
1. ASUS Keyboard
2. Device Policy
3. Google Hindi Input
4. Google Korean keyboard
5. Who Am I?
6. iWnn IME
statistics:
frozen system apps: 6
success count: 211
fail count: 3
ignore count: 651
partition count: 0
protected count: 0
bypassed count: 0
Device information:
Device: grouper
Maker: asus
Model: Nexus 7
Carrier:
Board: grouper
Bootloader: 4.23
Android OS: 4.3
updater-script analysis details:
FAILED: line #138:
assert(apply_patch_check("/system/app/Keep.odex",
"3af602f90589be934a937dc78a5ac0dfdb3031ad",
"a2e89c93ff50754e7abb82bffd26bfb58cd50aae"));
FAILED: line #144:
assert(apply_patch_check("/system/app/LatinImeGoogle.apk", "f9f2d31431a1ab8e8bb6a59d1140392271970038",
"50a127cea592446b11be96a166bc8d6a72d8dcd3"));
FAILED: line #410:
assert(apply_patch_check("/system/lib/libwebcore.so",
"0fc28968fe51732eec8659cbce2c59693437fa6c",
"776f151ca6eb6c2438d1dd2b06f55c2c7a375440"));
[/HIGH]
Hey palmtree! :wavey:
Lemme find the thread where I posted a special version of the OTA Verifier app that will display the actual SHA1 digests that the app sees so that I can compare my files against yours.
I've not yet installed the 4.3 OTA on my device, so I should be able to compare and see what is up.
I think the issues that I've seen and read about where various rooted apps that were monkeying with system files that you're not necessarily made aware of until it's too late (i.e., when you are ready to install an OTA :p).
(you're rooted, right?)
Thanks!
Yes, I'm rooted
Here's the output:
Detailed Analysis
- you have 6 frozen system apps; this may (but not necessarily) impact the ability of the OTA's updater-script to update these apps and cause the OTA install to fail
- there were 3 failed expressions; see below for the details about these tests that will cause your OTA install to fail
1. ASUS Keyboard
2. Device Policy
5. Who Am I?
6. iWnn IME
statistics:
success count: 211
fail count: 3
ignore count: 651
partition count: 0
protected count: 0
bypassed count: 0
Device information:
Device: grouper
Maker: asus
Model: Nexus 7
Carrier:
Board: grouper
Bootloader: 4.23
Android OS: 4.3
FAILED: line #138:
assert(apply_patch_check("/system/app/Keep.odex", "3af602f90589be934a937dc78a5ac0dfdb3031ad", "a2e89c93ff50754e7abb82bffd26bfb58cd50aae"));
[the SHA1 checksum for file /system/app/Keep.odex (adae4df9fc2334e417296f41cf048f471116fa45) does not match any SHA1 in the above expression]
FAILED: line #144:
assert(apply_patch_check("/system/app/LatinImeGoogle.apk", "f9f2d31431a1ab8e8bb6a59d1140392271970038", "50a127cea592446b11be96a166bc8d6a72d8dcd3"));
[the SHA1 checksum for file /system/app/LatinImeGoogle.apk (01afb9b584289f61e3ed81790b17a2e08a77dc71) does not match any SHA1 in the above expression]
FAILED: line #410:
assert(apply_patch_check("/system/lib/libwebcore.so", "0fc28968fe51732eec8659cbce2c59693437fa6c", "776f151ca6eb6c2438d1dd2b06f55c2c7a375440"));
[the SHA1 checksum for file /system/lib/libwebcore.so (285d200e9a68ad0f0d572f474ed40a88f058c959) does not match any SHA1 in the above expression]
(the above text has been copied to the clipboard)[/HIGH]
Oh, palmtree!
I just noticed / realized you are already on 4.3--so, this is yet another OTA? :eek:
I don't even have the Keep.odex file on my 4.2.2 N7, so I'm not sure how much help I can be with comparing my files to yours.
I take it you installed the 4.2.2 -> first 4.3 OTA with no issues?
Also, what root-related apps have you installed since then? They might have tweaked some of the files that are showing as not matching...:dontknow:
Oh, palmtree!
Yes, the build number on it is JWR66Y
Yes, if I remember correctly, I had no issues with that at all
Not really sure, other than replacing SuperSU with CWM Superuser when it was updated to support 4.3
:dontknow:
Got it to work
I happen to have a copy of the factory image for 4.3 (build JWR66V) for grouper on my computer. From there, it was a simple matter of mounting the system image to a folder on my computer, checking the SHA1 sums of the files in question, pushing them to the device via ADB, and manually copying them to their appropriate locations using ES File Explorer
Conveniently, the OTA breaks root
Reflashed Superuser via a zip file and it works
:thumbup: Awesome!
I was just gonna suggest grabbing the factory image and unpacking it to grab the files that are needed (I do it on my Linux system--do you use Cygwin or Linux?).
I still wonder if one of your apps is the one responsible for replacing those files in question? :dontknow:
Linux
As for the apps, wouldn't updates to the app have a different SHA1 sum than what the script is looking for?
I'm lucky I had that factory image on my computer already as the one for the version I was coming from was replaced by the new one in the list of factory images
Linux
Yeah, I'm thinking that the (root) app might update/replace one of those systems files which their own version (which is why you'd see three different SHA1 values (the new, unknown file from the app and the two values specified in the updater-script file (those values are typically the digest of the previous and current Android version of that file)).
I think we saw that the new SuperSU updated a file or two, but I'm not recalling that perfectly at this time :p.
If I'm not mistaken, the new SuperSU mods the install_recovery.sh file to run root at daemon, due to the way 4.3 looks at admin file directories.
