Root New power button mod?
Does this mod work for us? and which version the HD version or the regular one?
HD
Regular
Neither one of these work unless you are on a dedexed ROM which most custom ROM's are. Uncommon Sense for example has it built in. There is however a working version somewhere I am just not sure where it is.
So this will not work on a rooted Inc with Virtuous?
interesting i thought virtuous was deodexed, which version did you use the HD or the regular?
I am using fourth wave and it is deodexed but I may just hold off on using it.
Virtuous IS deodexed. But just because a ROM is deodexed does not mean this will install and function correctly. That is just one of the prerequisites.
I found one that worked on the deodexed stock 2.2 ROM and should work on virtuous.. lemme know if anyone need the link...
hd or reg?
i tried to flash it on to the phone, of course i could have just fahkered that up, but -shrug.
Ya I found one somewhere that adds reboot etc, but nothing with the hot boot and the new functionality.
Yea IDK what the hot boot is but I'm happy I don't have it, this is exactly what I was looking for and is perfect. Give the reboot, recovery and boot loader. what else could a rooter ask for. lol
try the cyanogenmod rom. it's built in.
I think so anyways...maybe it was the Ultimate Droid rom....hrmm.
Obviously not as streamlined as being in the power button menu, but rmk included QuickBoot in his 3.0.1 rom which has all 3 of these features as an option. It's also available in the market I believe.
You just click the app icon, it gives you the 3 reboot options, 1 click, and you're done.
