Help New problem: Sense music losing its memory
Brent372
This just started recently. I will listen to music. Then several hours after stopping, my music player widget and app both show "Choose songs from your library to play some music..."
This never used to happen. It would always remember right were it was playing when it stopped.
Phone has not been rebooted since playing stopped.
Stock Rooted ICS.
Thanks!
That's an odd problem that I've not experienced or read about. You might try removing and reinstalling your player. Have you tried a different player it see if it acts the same? I use the stock player and have never had it fail to bookmark my listening spot.
Not sure you can remove / reinstall the Sense music player... ????
