Root New Radio Update and DC 3.2 question
IsaacRCCL
1) I downloaded the new Radio update.. What do I do now? Move the META-INF folder and the radio IMG to the SD card? Or should I just move the entire ZIP file to my SD card and flash it?..
2) Once flashed, should i just remove the those folders from the SD card?
3) anyone else having trouble launching Qik on DC 3.2? I flashed the update/patch and it still FCs
As stated, flash radio from your SD card. Then you can delete the zip afterwards. As for dc 3.2, the patch is only for 3.2.2 and trev also released a 3.2.2.1 that has the fixes patched up. So if you are still on 3.2 then you might need to upgrade.
