Root New Rooter - Need help removing bloatware/stockware. Please help!
Remuhnes
So I am new to all of this, and I just got this phone for xmas.
I just rooted my phone successfully.
My goal is basically to remove all of the metro apps, because they lurk in the back all the time.
I am not sure how to do this, and I really don't want to brick my phone.
Can anyone help?
Thanks!
get titanium....somewhere on the net.... and you'll be able to uninstall any app you want. dont remove something your not sure about...theres a thread out there
I did get titanium but it says I dont have root access and busy box,
but I have the super user app, and I dled busybox..
Go into your settings>about phone section and look under SW Version. Is the a B at the end or a C?
If its a B try rerooting, if its a C then thats the update and theres no root that will work for it right now.
