Help New Tablet - Problems with SD Card?
andesng
Hi everyone. I just got my new tablet today. I've never used an Android product before, and I'm very confused about what to do about the SD Card. I've inserted it, but it keeps saying that it is blank or has an unsupported filesystem. I've clicked the button to format it several times, but to no avail. Any help?
if its a micro sdcard, try sorting it out on your pc first you can get a usb adapter that enables it on your pc/laptop then see is there anything on it from that end to delete or format.
Hy, I bought it too and have the same problem with my tablet about the SD Card... it doesn't recognize the SD Card.
Can you find out the solution about how to make it work well?
If you could find something please let me know it because I looking for a solution .
Thank you, me email is soloparainformacion@orangemail.es
it will only recognize a fat32 formatted sd card.
so format it on your pc first.
hope that helps
Russ.:cool:
Problem there is that if the USB memory device has been 'optimised for performance' you can have NTFS selected as the format to be used.
It would be best if you used SDFormatter.exe on the pc for formatting to FAT32
