Help New to Android- Need Some Help...
I have had my Huawei Ascend for 3 days now (I'm with Metro PCS, incase that's important). The first night the wifi was great! However, since then I cannot get it to connect, no matter where I go. Yes, I went to Settings/Wireless&Networks/Wi-Fi... It's checked ON. I've tried re-setting my router (and the others I've tried to connect to), so I don't think it's that. When I try to connect, it says "obtaining IP address from (insert network here)" but it never goes any further, it just says "Failed". Am I missing something??? A little advice would be very much appreciated! :)
In that case, I'll recommend trying one thing before going back to the store: a full factory reset. This will wipe all data, including anything you've downloaded and installed, and put the phone back to the same state it was in when you got it. The process is this:
Turn off the phone, then press and hold the Volume Up, Send, and Power buttons. Release all three AFTER phone vibrates. Select Wipe Data/Factory Reset, choose Yes, then wipe cache partition, choose yes again, then select reboot phone when that is complete.
If you don't want to try this, then I'd recommend going back to the store and seeing what they can do, which may include this step of troubleshooting, so save any contacts, etc, that you want to keep just in case.
is ur ip lock ? Stupid question , r u using ur Own IP ? LoL
cuz last night with the storm , power went out on me
so I had to log in and get the Code again from NetGear
Wi-Fi check , Wi-FI setting , Mobile networks -Data Service
Also Try UnCheck WiFi , then Recheck it again Or push Menu and Scan again ???
Accounts & Sync - Background Data Make sure all those are check
Warming : if u r doing a Privacy - Factory Data Reset
Everything Will be GONE , even urContacts , so I hope u got Metro Backup on ur Phone Plan
hope one of this will help u , Good Luck
What about going into the wifi settings and press and hold on your SSID and tell the phone to Forget this network
Then reconnect to your own network?
anyone having this problem in the future ***
It could also be Metro updating their system, expanding coverage or you may simply call and have your phone's data connection reset and that often fixes the problem!
Check with your service provider first! :p
I had the same problem... Turns out it wasn't my phone. I had too many things attached to my router. A Blu Ray player, A Roku box, 2 Laptops, A Nook, One desktop computer and my phone... Once I disconnected the Nook and rebooted the router I connected just fine. Check it out before you do the hard reset.. Could save you a lot of time...
