Root New to Bolt need some help
I am trying to do the checksum step on my phone via the Scary alien app, but don't know where to go to compare it to the developer's checksum. I am planning on using the stock w/out bloatware rom that you suggested to me.
EDIT: Found it.
There is no option to turn off. It one rolls out it may prompt you to update if it doesn't and it soft bricks your phone then it should be easy to fix. All you really need to do when an OTA cows out is flash the new OTA rom to avoid getting an update.
