EmbraceMassage
Hello.. I found this thread and have the same need!
Help..
Simply put, what I (and seemingly hundreds of others!) want is a way of selecting a contact from the contact list, opening the contacts menu (or maybe long-pressing on the contact name) and clicking 'Create Appointment'. This would then open the calendar app (stock or A.N.Other) at a new appointment and would then:
(1) automatically fill in the contact name in the subject field (perhaps using text such as 'meeting with nnnn' as a default)
(2) automatically add the default contact address as the meeting location (or perhaps a combo box allowing selection from Home Address, Work Address, other)
Help..
Simply put, what I (and seemingly hundreds of others!) want is a way of selecting a contact from the contact list, opening the contacts menu (or maybe long-pressing on the contact name) and clicking 'Create Appointment'. This would then open the calendar app (stock or A.N.Other) at a new appointment and would then:(1) automatically fill in the contact name in the subject field (perhaps using text such as 'meeting with nnnn' as a default)
