Dante04SRT
I just installed Cognition tonight - It was my first ROM installation on my Captivate.
I wanted a version of Froyo primarily for 2 things - I wanted the WAP feature and the ability to shut off data usage. I like the battery % that shows on the battery bar too.
After installing it, I'm a little.... well, I dunno. It almost seems quirky. This is where I'd like input if you've got some...
First thing I tried to do was change my background. I went into "My Files" and then to my Backgrounds folder. I was surprised at how long it took to load a picture in the viewer - I'd select a picture and it would LITERALLY take 10-12 seconds before the picture would show up on screen - The screen was just black for that period of time... Then if I tried to change the wallpaper, same thing - It would "change" it, but it'd be like 15 seconds before the changes would take effect! Very odd, compared to Eclair 2.1. It seems that most pictures & video are acting this way...
I've also noticed some lag with the keyboard - at least the Swype one - Not sure if it was the app, but typing in Facebook was almost impossible with it. I was glad I could still use the Samsung Keyboard, as it is my favorite currently.
Another thing I've noticed is in calls - If I was on a call and then went to any other app, if I tried to come back to the phone section, I NEVER got the hang up option - It took me to the dialing screen, not the "in call" screen. It seemed the only way to hang up the call was to go to the status bar thing up top and select "End" there. Kind of a pain as I was used to going back to "Phone" and hanging up there.
Another odd thing was noticed in "My Files". If I was anywhere in it and clicked the back button, it would back out of the folder page and I'd come to a page that simply said "No Files" - If I press anything other than the Home button, the phone freaks out for a second and then the "Force Quit" message comes up. I never had that problem with Eclair.
A few other things... My "Daily Briefing" stuff is missing. I've looked everywhere but can't seem to find it - I really liked it for seeing my weather! Any ideas?
Also, in my address book - In 2.1, I could stop the sim card entries from showing up (and being duplicates), but I can't seem to turn them off here. Ideas?
Anyway, I'm by no means unhappy with Cognition, I have just noticed those few things that seem buggy to me. Am I alone or just missing something? If anyone has any suggestion or help, I'm all ears. I'm really new to this all, so any help would be greatly appreciated!
Thanks,
Dan+e
Thanks,
Dan+e
