Newb question
timx2007
So if I root a Sprint Marquee, it means I can use it on Boost Mobile, correct?
Also, is it possible to use the Marquee on a pay-as-you-go plan on Boost Mobile, or are you required to have a data plan?
Androids require the Android unlimited plan on Boost, which now starts at 55 a month.
And Boost now sells that phone, so I don't see why it wouldn't work.
If you FLASH it to Boost then you can use it as a Boost mobile phone BUT rooting the sprint version would just give you root access. Rooting the phone will not enable you to walk into a boost mobile store buy minutes and allow you to use it on their network though. I could be wrong...Im not an expert BUT that is what I think.
