Newb Questions
Hey there.
I just ordered my Hero the otherday and am just doing some more research before it comes.
Im wanting to make some backgrounds for it and was curious if when changing from each screen does the background also change? or does it stay the same? Might there be an option for either?
I think i read somewhere that the correct wallpaper size is 640x480?
Thanks in advance.
You can have one background for the lock screen.....320x480 pixels.
Then you can have another background for the home screen. This needs to be 640x480 and does scroll left and right as you change screens. But it doesn't *all* move, so your central homescreen shows the central 320x480, then scrolling it to the right will show a slightly offset 320x480, until you are at the far right when it will show the far right 320x480.
Does that make sense?
