Help newbie help int mem limitations
eddief40
Hi all, i am about to go and get an optimus from the carphone warehouse this afternoon. i know it has a limited int mem but how small is it in reality. i am upgradeing from a normal moby and wont to play with the apps and stuff. so what is the limitation of it. any thing you can save to the sd i would to free as much space as possable.
also the cpw has a differant version of the phone to outhers acording to some of the posts here. what is the differance of a cpw lg and say an orange one. thanks
eddie
Just a word of warning if you like to tinker with your devices , the carphone warehouse version of the gt540 has part of the menu that enable rooting removed.
according to the storage monitor app, my gt540 only has 140mb usable storage memory , and only 56mb of that is free with my currently installed apps.
So it`s not a lot of memory to work with, and since you need android 2.2 to use the sd card as storage , and 2.1 is most likely the limit of the gt540 unless we get an hacked android 2.2 software.
