Root Newbie - help please
Dave7377
newbie - how do I turn off the vibrate and sound when I send a txt ? keeps doing it when my balance flshes up . Most annoying, wasnt doing it b4.:mad:
Please ignore, wrong place yeah ?
Not in either place.
Think it is to do with the pop up message for balance ?only way to shut it off is to put the phone on silent ! very annoyng
help ????
Assuming you're using the stock SMS app : menu > settings > 2nd option down is 'play notification sound', 4th option down is 'vibrate'. You need to be in the screen that shows all threads/conversations rather than in a single conversation screen to get the settings menu.
those options are both unticked.
It is when my balance pops up that is the issue, so outgoing txts, or when a incoming txt costs that the noise/vibrate happens.
That is what needs to be turned off.
What do you mean by balance? Are you talking about when it brings your messages to the front? It just pops up like an IM or something?
He has a carrier notification after using credit that tells him what his credit balance is
