Help Newbie Help
We just ordered the 10.2" SuperPad tablet and I am looking for some basic help. We've never had a smartphone or tablet before & we want to get the basic how to in order to get the most use out of our new toy.
We mainly want to use it to play basic games, watch movies, use as a ereader, check email & surf the web. Nothing too in depth. Can someone direct me to a great website that spells most of this basic info out!
Thanks!
First off I would change launchers. The stock launcher is garbage. Try launcher pro or ADW Launcher(both found in the market). After you get into the market the first time, http://market.android.com is your friend(used from a pc). Basically your starting point for most things would be the android market. There are also tons of forums, blogs and the like out there to help you and people like us to help you out with specifics. So if you have any questions, just ask.
Android is pretty easy to work with, it's mostly click(touch) and you're off and running. I know I'm over simplifying, but like I said if you want to know about a specific task I can try to help. Otherwise I'd suggest just playing with it and getting a feel for the android OS.
android is kinda the linux of OS devices aint really for newbies to be playing with
but the installed apps are pretty straight forward for what you described your looking for. watching films ebooks music browsing the net etc unless your of somewhat comfortable with computing...STOP.
