Help Newbie SGS2 questions
bgnecnakh
Hi
I used all my resources from xda, but i get no support there as far as questions
so allow me to try here:
I updated my sgs2 from 2.3.4 to 2.3.5 rooted. All success.
Now to get rid of the yellow triangle, I used superoneclick
Everything works up to step 6 and it freezes. Nevertheless,
I did manage to get rid of the triangle with that. Weird.
How do I know if my phone has successfully rooted?
Under applications, I do see CMW and superuser.
How do I install non-market apps on my android?
Is it as simple as tick the check on the Unknown Sources?
Or is it better to use side loading machine? as far as viruses/spams concern.
I know it's a lot of questioning, because this is new and exciting!
Thanks in Advance!
