Root Newer kernel or stability?
ccsoccer03
I was wondering if anyone knew of development that could possibly push the limits of our phones even further or stabilize phones that cant meet the 787 or 767 mark
i get a stable 767 on my ally all the time, it never crashes. i had a problem with velocity.3 with the newest oc kernel where id get kernel panic even when i re-flashed and cleared everything off my phone. so i switched back to velocity .2 with the gnmturbo4 kernel and it runs faster then my oc droid(maybe be due to the ally's smaller screen):D
here's my setcpu profile so that you can try this if you want
(it saves a bit of power too)
charging full 768max 320min on-demand 50%
battery<80% 748max 320min on-demand 50%
battery<65% 600max 245min Conservative 50%
battery<30% 320max 122min Power Save 50%
battery<10% 122max 122min Power Save 50%
I used myfishbear's setcpu profile idea on my phone. It does seem to help with battery life quite a bit. I'm using Velocity 0.3 because I can't figure out how to set 0.2 up with app2sd. (LOLz at myself)
