cool.gautam
NEW KERNEL LINK ADDED PLZ DOWNLOAD AND FLASH THAT , NO RESTARTS AND LONGER BATTERY LIFE NOW
IF U LIKE MY POST HIT THANKS PLEASE.
ROM - Asevmaxx v 2.2.1 ( with flash )
Pros-
flash supported , better benchmarks and all features of sam's and playfugod's rom
PLEASE DOWNLOAD AND FLASH IN ORDER AS IT IS WRITTEN PLZ.
{ROM}
1) reboot to recovery
2) wipe dalvik cache
3) select install zip from sdcard and select the rom
4) reboot
LinK = Multiupload.com - upload your files to multiple file hosting sites!
HIS IS THE new KERNEL
INSTALL
1)reboot to recovery menu
2)take back up[important]
3)wipe cache and dalvik cache
4)flash kernel
5)reboot
LinK= Multiupload.com - upload your files to multiple file hosting sites!
AFter flashing it.....download adobe flash player ans install
YOU CAN CHECK FLASH VERSION BY VISITING What is my Flash player version? WITH STOCK BROWSER
I HAVEN'T TESTED 10.3 ON THIS KERNEL IF IT WORKS PROVIDE LINK BELOW .THNKS
here are some screenshots--
IF , problem while connecting usb
1) connect to pc/laptop
2) go to settings--> applications--> development
3) USB debugging will have a tick against it...
4) First untick that it will show USB connected and then again tick that it will start debugging
5) u will have to do this only first time
Pros-
{ROM}
4) reboot
INSTALL
4)flash kernel
5)reboot
