Root Newest true "1 click" root app released
Lock-N-Load
Android Expert
Just released...
You no longer need a PC to root your device and can instead complete the task with the freshly released z4root from developer RyanZA. The app contains one button that will perform all of the behind-the-scenes dirty work. It should also install busybox when finishes, but if it doesn
well its kinda new but i already knew about it for a few days now.:p It works though as I have already used it root my cousins droid 2 yesterday.
true. i havent seen other posts at all on that app. but its actually a good app. Had the phone rooted and busyboxed within 5 minutes. I would donate if i could at the moment.
this works for the d1 right? i am going to root my sister in laws droid and if I can use this to do it instead of the old fashioned way that would be awesome!
My three D1's are rooted the old-fashioned way... However, I tried this today for a friend's D1, and it failed. Tried 4 times - failed, rebooted tried twice more without success. I had my hopes up...
Mine also failed. I'm have the d1 on FRG22D. goes thru the motions, reboots. It added SUser, but no apps are listed. tried to load busybox, with no success.
Any suggestions?
Just added support for Droid 1. Update is in market. I haven't tried it yet though to confirm. However, people posted in the comments on the market that it works.
Confirmed working on my original Droid! (Already took Xanax, thank you very much...)
Now what???
i hope this works
guess it doesn't work? i loaded this onto sd card and used estrong file explorer to install app. opened app up and all it did was restart my motorola droid 1...?
i hope this works
maybe try emailing the apk to yourself and installing that way? just as a test. did it even "open" or just restarted the phone?
