Help Newest Update Question
My Evo asked me to do the update and I declined, how do I get the update back? I went into setting and checked for an update all it does is just say checking and nothing happens. Any thoughts are helpful. Thank you in advance. Also sorry if this is a re-post, I looked for a while on the forum and couldn't find anyone asking about this. Thanks again.
did you check all of them for an update if not try that if that dont work i once had this happen you need to pull oyur battery for a hard rest and then go back into setting an check if all else fails after that call sprint lol:)
