Newly rooted hero with Fresh 2.3.3 installed!
texas83
I am not tech savvy at all and I just pulled this off! I rooted and installed Fresh 2.3.3. I've read that you need to change the "kernel" but dont how to do this. I've searched and read and am only getting more confused.
I found this thread [KERNEL][7/22/10]Darchstar's Overclocked Undervolted kernel for senseUI roms vUV 2 - xda-developers but its not making sense either. Also read about SetCPU to increase speed. Can someone please post up links and explanations? I need help!! thank you in advance!
If you want to overclock, just download the module remover zip and one of the kernels for fresh from that thread (the ones without mem tweaks work best). These are all flashed through recovery the same way as you flashed the ron but with no wipes. Just flash the module remover then your kernel then reboot, don't forget to nandroid first.
The higher the number (768mhz is the highest) the faster it will run. Once you've installed that kernel you are officially overclocked. To confirm this, download system panel from the market and once you open the app you will we that your cpu clock speed can scale all the way up to 768 instead of the stock 528.
Just successfully flashed the remover and Fresh21_v4_768_M, rebooted, systempanel still shows the cpu maxed out at 528, any thought of what might have gone wrong?
just tried flashing the removed and kernel again, and the phone did not like that at all. it just went into a boot cycle, so I had to restore a nan backup. strange, maybe ill see if I have better luck with the 710
I was able to flash the 768 and system panel confirmed that it worked. I am also using setcpu app to kick it up a notch. The phone is faster than stock, but not drastically faster. Any other tips to make it faster? What is Gumbo kernel and is it better? thanks!
some phones don't like being clocked that high and will boot loop as a result, try the 710mhz version.
If you want an extra boost, jit is the way to go. Although jit does not like to run on sense ui that is oc'ed over 691, anything above ends up in random reboots. So jit with clocked at 691 fairly stable. I would post a link if I could, but I'm at work right now and I'm limited on what I can do on this computer. Check out XDA, you should find it there.
P.S. I prefer OC widget than setcpu, but it's your choice.
