Help NewsRob Pro Widget
dgsull
Yesterday I downloaded NewRob Pro and and put the widget on my home page. Later in the day my Incredible got warm to the touch and my battery was low. I remove the NRP widget and things seems to be ok. Anyone else experienced this?
You need to mess with the settings. Check the synchronization, see the refresh interval, it's probably set to refresh in a short period of time. I set mine to manual.
Thanks, I had it set at 30 minutes. I'll back it down. Actually I don't see a significant need for the widget anyway.
