Root next step w/terminal emulator
thehulk20
Member
i am ot having the best of luck. i have the basics for flashing roms. currently i have apex 1.3 and pretty much going to stick with it for a while.
i am ready for the "next step" and want to use the terminal emulator. i have opened it...typed in "su"...then "apextoolbox" (for example)...and i get "not found".
am i missing something?
The toolbox is new in version 1.4 I believe. Just update to 1.4, you *shouldn't* even have to wipe data/cache. ( I didn't ). Once you've done that -- the toolbox ( which is amazing ) should be there for your pleasure.
