Nextbook7 P12, how to get Flash 11.1 to install?
lokiare
how can you install flash 11.1 or higher on Nextbook7 P12. It comes with 10.X installed, but many flash games don't run on that anymore. I am unable to uninstall the stock flash 10.x. The only option is to disable it. I may have to root this device, but there doesn't seem to be any good instructions on this. Is there a general way to try to root 4.0.4 tablets?
Model number Next7P12-8G
http://forum.xda-developers.com/showthread.php?t=
That should sort you out with the flash apk, there are instructions there and whilst it says it's for jellybean, the same method should work for you.
Rooting is generally device specific so I'll need to have a hunt around, see what I can find on your device. Not promising anything though. :)
Link doesn't work and when I try using most tutorials it says something about not being signed by the same people and won't install. Its ok though. I returned it because everything else that I could find on it says you can't put flash on it, and you can't root it, etc. The whole point was to get a cheap (under $99) android 4.0+ tablet to run facebook flash games on for a not so computer techy person.
(note: the link you posted doesn't work)
Yeah, it chopped a bit off when I copied/pasted, I was using my tab and didn't notice, sorry.
Is the N7 too pricey? Acer have also just launched a tablet that's did cheap if you're still looking for something?
