Root Nexus 4 Factory ROM?
strausd
Can anyone point me in the right direction for the factory ROM for the Nexus 4 on Android 4.2 or 4.2.1?
Here is another guide that tells how to restore stock in its entirety.
http://forum.xda-developers.com/showthread.php?t=2010312
If you want an easy way here's a stock ROM you can just flash in the recovery, but your phone still won't be 100% stock..
http://forum.xda-developers.com/showthread.php?t=2019243
Thanks for the info. I saw that ROM earlier while searching and read some of the comments. Apparently it actually isn't a complete stock ROM.
And the phone doesn't need to be 100% stock. Just needs a stock ROM, unrooted, and locked bootloader, correct?
I was going to make another thread, but seeing as how we're talking about factory ROM, what's the deal with the factory ROM not being listed on googles site? I read about this a few weeks ago, but noticed yesterday its still MIA! It was incredibly difficult to find a working link.
Yes, a very curious thing that a search for "nexus 4" on https://developers.google.com/android/nexus/images yields nothing now, when it was there when I purchased an N4 at the original Nov. 13th offering.
Is mako200.tar.gz at all helpful to you, or anybody?
[edit] It's also curious that http://code.google.com/p/galaxy-nexus-linux-toolkit/downloads/list?can=1&q=%22nexus+4%22 lists both the 4.2 and 4.2.1 as "deprecated". [/edit]
[edit] It's also curious that http://code.google.com/p/galaxy-nexus-linux-toolkit/downloads/list?can=1&q="nexus+4" lists both the 4.2 and 4.2.1 as "deprecated". [/edit]
Correct me if wrong here, but that file seems to be a bit small for a factory ROM >.>
I just had a problem where some how the ROM zips I downloaded and my NANDroid back up were wiped from my device, I didn't notice this until after I wiped and had nothing to flash. I did have Nexus 4 Toolkit installed on my computer though.
I used option 9 to download, extract and flash the stock rom. It failed however. I found a working file here: https://developers.google.com/android/nexus/images#occamjop40d
I downloaded that .tgz placed it in the correct folder for N4 Toolkit and it used it to flash me back to stock. Was quite a scary experience.
Link to Nexus 4 toolkit: http://www.addictivetips.com/androi...-unlock-recovery-adb-fastboot-drivers-backup/
