Help nexus 4 make messaging text clearer or bigger?
mm43
Is it possible to change the size of the text you type when sending a message on my android nexus 4?
Don't want to enlarge it for anything else though.
I'm running a custom ROM based on stock and on my messaging app, if I hit the 3 dot menu button, select settings, scroll right down to the bottom, there's a setting called Message Font Size. Do you see that?
If not, I'm not sure you could change it with the stock app, you might need a 3rd Party app for that.
Thanks but nothing in my settings menu about message font size
Only delete old messages delivery reports etc.
