Root Nexus 4 Suicide
Sorry,
I have been getting ready for an evening out and will be away from my PC. I'll still be on in mobile mode but of course in a less robust manner. Hope everything works out. I would continue to help if I didn't have plans tonight.
jmar
Okay, I got the fastboot drivers installed. If I go to Advanced > List devices my device shows up. I'm set, right? Nope. When I try to do a backup of the SD it says I need USB Debugging enabled.
No big deal, i'll just do a pull. Command prompt still won't work with adb commands. Okay. I'll do a pull from the toolkit. Pull only works on a stock Android build.
Now what?
Unfortunately not, but I do have a working phone now.
I still haven't figured out what caused my ROM to become corrupt in the first place. As I said in my first post I was just sending a text when it crashed on me. Weird..
Indeed. Glad you're up and running. Got all drivers and adb and fastboot working?
Glad you got the device working. Sometimes you just have to cut your losses and bite the bullet to return to stock. Lord knows how many times I had to do it on my Gnex when the first batch of 4.1.1 roms came out.
