Nexus 5 Lag
After factory reset phone works fine. After updating apps, lags starts to appear. Yesterday my phone worked very fine. Now its laging again. Maybe "ROM" or "Kernel" can help me? Any good ROM or KERNEL?
Animations off or 0,5 - Didn't help
Another launcher - Helps 50%
maybe it's a dodgy app you're installing. Give us a list of apps that are installed
I'm updating all apps that are built into nexus 5 (Maps. Google drive, Hangouts, Play Games, Play Music, Quick Office etc)
My nexus 5 lags and works like a speedhack. Its 3x faster than it should be. I think i need another ROM or Kernel. My phone is fcked up!
speedhack?
And on stock???? :confused:
If you're rooted why stay on stock??? Maybe Slim? Any rom that is minimal should be way better.. If you have TWRP/CWM just wipe cache and see how it works after a while. That was a usual fix on my Nexus5 and Nexus4. Also make sure to close apps that you've stopped using. Help with battery, and performance!
Today i did factory reset again. I turned off animations, google now, and "ok google' thingy. And now phone works fine. At least for now :D
