Due to problems when previously trying to root I had to flash the factory image, and that all went fine, and my bootloader is still unlocked. Am I right in assuming that if I flash a recovery and the SU files, this won't factory reset my phone will it? [After flashing the factory image, I needed a working phone so it got set up over the next few days of using it and now it's set up how I want it!]. So confirmation on that would be appreciated.
I want to install Franco Kernel, is this really as easy as installing the zip in a recovery and rebooting the phone? Does it do a factory reset? Will I lose my phone's set up? Is it ok to use Franco Kernel with the factory image or does it have to be used with a custom ROM or does it not matter? Will I see benefits using Franco Kernel with the factory image? And finally how do I revert back to the stock kernel? Just flash the factory image again?
Thanks guys.
