So first off, I looked through the forums and found nothing like this, I could have easily missed something and I apologize if I did.
So I had a custom ROM on my Nexus 7 2012, I went to restore to stock to get the kitkat update last night. Apon reboot it was stuck in the flashing nexus X. I got it to restart but the boot loader is completely corrupted, and I feel pretty confident I have ruined my tablet.
The symptoms:
I can boot in to bootloader, if I try to start the Recovery mode, I get "Booting Failed"
I can plug it in to my computer and NRT can see the tablet in fastboot mode, I can even restart the tablet back to bootloader.
I have tried to boot new bootloaders on it but keep failing.
I tried to put the stock OS on it with NRT and I get the following results:
Flash Stock + Unroot...
erasing 'boot'...
OKAY [ 0.020s]
finished. total time: 0.020s
******** Did you mean to fastboot format this partition?
erasing 'cache'...
OKAY [ 0.040s]
finished. total time: 0.040s
erasing 'recovery'...
OKAY [ 0.012s]
finished. total time: 0.012s
erasing 'system'...
OKAY [ 0.050s]
finished. total time: 0.050s
erasing 'userdata'...
OKAY [ 0.998s]
finished. total time: 0.998s
sending 'bootloader' (2100 KB)...
FAILED (data transfer failure (Unknown error))
rebooting into bootloader...
FAILED (remote: (Nv3pBadReceiveLength))
finished. total time: 0.010s
archive does not contain 'boot.sig'
archive does not contain 'recovery.sig'
archive does not contain 'system.sig'
Bootloader Version...: 4.23
Baseband Version.....: N/A
Serial Number........: 015d24a42840120f
checking product...
OKAY [ 0.030s]
checking version-bootloader...
OKAY [ 0.010s]
sending 'boot' (4896 KB)...
finished. total time: 0.160s
Booting up your freshly flashed stock device...
Wait for your device to finish booting up...
- It may appear to be boot looping; just wait...
- It could take 5-10 minutes; please be patient...
When its finally booted back up, please remember
to re-enable USB debugging if you plan on using
the toolkit to perform other operations.
NOTE: If this process was too quick and your device
is still in bootloader mode, then flashing stock may
have failed or been incomplete. Simply check the
log above: if you notice it skipped steps because it
didn't meet certain requirements, like the bootloader
or baseband version, then consider enabling 'Force Flash'
mode in the toolkits options menu and trying the
'Flash Stock + Unroot' processs again. Cheers.
Press any key to exit...
ODIN does not see the tablet, and it also fails if I try to use my Windows PC command prompt to flash the table.
Any thoughts or suggestion please? Or I am correct to believe I have ruined my tablet? I thank you all for any help!
P.S. - Be aware I am still very much a noob, and I am still learning.
The symptoms:
erasing 'boot'...
OKAY [ 0.020s]
erasing 'cache'...
OKAY [ 0.040s]
OKAY [ 0.012s]
erasing 'system'...
OKAY [ 0.050s]
OKAY [ 0.998s]
checking product...
OKAY [ 0.030s]
OKAY [ 0.010s]
