nexus 7 (2013) soft reset issue
sometimes when I power the screen on, the touch screen is unresponsive, which is a common issue that im not too worried about. with the screen not responding i am forced to do a soft reset. the problem is that when i soft reset the device, the device takes 20-30 minutes to soft reset! it stays on the google screen for that long, though it eventually does soft reset. it is extremely annoying and i want to fix the problem. i do not have apps running, i kill them when im done using them, so that cannot be the problem. I do have a decent amount of video game emulators on my tablet, if that could possibly be the problem. also, could someone give advice on how to decrease the unresponsive touch problems? also the soft reset does get rid of the touch problem, i just want to make the time MUCH shorter. thanks.
What do you mean soft reset? You mean a reboot? That should not take a half hour. A regular reboot should only take like 2 or 3 minutes tops. What Android version and are you rooted?
