I'm really considering the Nexus 7 as it looks very slick overall. The only issue I have is with the lack of connectivity. I currently have an ipad3 with ATT cellular connectivity, but I've been thinking of getting a smaller device for a while now. The ipad mini is not on my radar due to the pricing, I can't see paying close to 500 bucks for a 16gb cellular model with yesterdays specs so Apple lost me as a customer.
One of the main things I use my ipad3 for is Navigation. I use Navigon and it works pretty nicely. What are my options with the Nexus 7 since it doesn't have cellular connection, but from what I understand it does have a GPS chip? Are there navigation programs which would allow me to download all the maps and not have to connect to cellular and allow me to navigate only using the GPS? Is this practical, or will the maps take up too much space?
once you dl the directions, you can disable the tether. After a distance, the map will lose detail, but your route and turn by turn directions will still work. It also caches a 'snapshot' of the places you need to take a turn/exit so you will not get confused.
