imnotmikal
Android Expert
Hey guys, I don't really come around here much anymore, but I thought since this project is an Android project too, I'd post it here.
FIRST: I don't want to hear about how this is a stupid idea or anything like that.
Anyway, here's what's going on:
I will be installing a Nexus 7 in my dash, completely automated, integrated, and removable. When it is slid into the dash, it will automatically turn on Wifi, Bluetooth, and Music, thanks to NFC tags. The N7 will stream audio to a Bluetooth receiver, which then feeds into an EQ. From the EQ, it goes to my sub and 4 channel amps. The N7 will be kept charged by a hard-wired POGO pin charger.
I'm debating whether or not to make a pod for my GNex (also removable) that will use NFC to automatically turn on Wifi Tether.
Update 12/5
My prototype POGO pin charger works! Although currently looking like a death trap, I will clean it up and hard wire it into the car when it completely ready. (Testing was done with my GNex. I know the pins are in different positions, this was just very early stages of development, for testing purposes.)
Update 12/7
The Nexus 7 will be bought on 12/9. NFC tags and RCA level controllers were ordered and should be here in a week or two.
Update 12/9
Picked up the Nexus, and began cutting my dash to fit it. More cuts will be made, and then fiberglass will come.
Update 2/6
The dash is coming along quite nicely. Fiberglass is done, time for body filler.
Update 12/5
Update 12/7
Update 12/9
Update 2/6
