This is where the special version of TWRP comes in. You don't just flash it as you would any rom. That would overwrite your current rom. You need the modified version of TWRP with the MultiROM options in the advanced menu. When you choose the add rom option, it installs the rom to your internal storage as opposed to installing it on /system.ok thanks. so i can just flash with timurs rom with elementalx still on there. i aint gotta take off
), and then for your Secondary (or Tertiary or however many you want - you're limited by device storage space) ROM just install a stock LP rom and flash timur's on top of it (or whatever else you like
). That's the whole point of multi-rom install
. The only requirement is for the kernel you use with Primary ROM to have multi-rom support, and if you use ElementalX it has so you're good to go.
