Dark Matter
If you are rooted you can change the stock lock screen, to the Nexus One Lock Screen.
All you do is rename htclockscreen.apk to htclockscreen.bak using root explorer.
Credit P-funk
/system/app/htclockscreen.apk
reboot phone and it will change to the nexus one slider lock screen.
If you want to change back to stock rename htclockscreen.bak to htclockscreen.apk then reboot phone.
Do this at your own risk.
Credit P-funk
