adamlovesu
do you think your device will last untl next year or possibly 2?
well the hardware i know will lol.... i just dont wanrt to get it than 2 mts down the road i get dust.............................
kindly explain what is so troll about my posts on this thread?
don't listen to adamlovesu, he appears to be a troll.
I find the capacitive buttons a 6/10. While I nearly always hit them when I want to hit them, it bothers the **** out of me when I hit them accidentally. That happens once in a while as suggested by oniongirl.
I'm happy with everything else. One downside for me is about something you didn't inquire about: I'd like to have a store (similar to the iTunes store) that allows me to download movies and TV series. Movies look stunning on the N1 and I'm too lazy--and have legal concerns--about transcoding stuff myself.
The phone gets warm while charging, but then what phone with this kind of hardware doesn't?
The N1 is my first Android phone and I really do like it.
-the capacitive buttons - 8/10
I sometimes skim them and the phone vibrates but the button press does not register and go back.
-the trackball - 8/10
I don't use it much but I think it is a little to stiff but use able when you need it.
-the sensitivity and accuracy of the screen - 9/10
My screen is very accurate, sometimes when I click a widget icon in the very corner of the screen it does not register but I think that is the widget not the screen causing that problem. Other then that mine is really good.
-the battery life - 7/10
Battery drains quickly but I get a normal days use out of mine.
-the speed of multitasking / day to day use - 10/10
It can lag sometimes but that clears up fast but I also have a lot of widgets running all the time. Before I added all of them it ran faster. Great to use everyday and nice hardware that feels solid in your hand.
I think the phone is really good, the only time I ever have a problem is when I become impatient and try to apply something like a live wallpaper before it loads. The phone can lock up but a quick battery pull will fix it and really how many times do you change the wallpaper, it is not a frequent activity so it really does not bother me at all. Just be aware there are some issues but I haven't seen any on my phone that I can't live with.
I have no dust under the screen (no cover or case just using the sleeve that came with the phone) and my battery only get hots when I charge the phone.
Generally work well. Occasionally hit by accident when texting etc. But as the N1 is multi-tasking, you don't lose whatever you have typed.
-the trackball
Works more accurately that my BB Curve. Hardly used except for text editing as the screen is so good for most things.
Great.
-the battery life
Average for a large screened smart phone which can handle lots of processes. Not a problem for me to charge overnight. Always lasts the day.
Speed is generally good, if you have a lot of processes running the home screen may lag slightly. No worse than I've seen on other phones and easily fixed with a task killer.
Other gripes people have and my comments:
Battery overheat. Never notice and not had a problem My battery widget has reported temperatures of around 32 deg C. It is currently fairly idle at 21.6 deg C.
Dust in screen. No problems here.
3G issue. My only issue is that I live in a weak signal area and 2 bars of GPRS signal can reduce to 1 or none occasionally when I hold the phone. In stronger areas and 3G areas the phone works brilliantly.
Battery pulls. Done once. Less frustrating than when my old iPhone 3G threw a wobbler and all I could do was hit the power button and the home button (a lot) until it righted itself.
Media player. Not a concern of mine as I still tend to use my iPod Touch. However I have had a quick go with DoubleTwist ad it pulls all your music from your hard drive and allows excellent sync management with the N1. Played a film to try it out and seemed fine. If I was bothered I would probably get another media player app from the market for the phone front end though.
Track ball. I don't care that it isn't working in multicolour at the moment.
Scratches build quality. So far my unprotected N1 doesn't have a scratch on it. Build quality is good. However I would like the back of the phone to be less slippery - I still feel a bit nervous during one handed operation.
According to someone else on the xda forums: "I just seen the disassembling video for the Nexus One on Youtube and said the trackball was the same as the blackberry's. I have a spare black trackball from the 8900 and want to clarify if they actually are the same. I know down the road the trackball will soon start to yellow or get dirty so I think replacing the trackball and even cleaning out the dust specks under the screen." So yeah.How does the size of the trackball compare to that of a BlackBerry? I like the idea of the trackball simply for precise text editing. I have heard that it was supposed to show multicolor, but I'm not sure I care that much about it either. Is the trackball the only notification for messages and such?
Don't get it. You won't be able to put it down for a week. If you do get it - get the Dock while ur at it.......
What real advantages does the dock bring?
It looks good by A/V equipment. It is bluetooth enabled so you can stream music from your phone to the stereo if you are within bluetooth range. But you can probably find a product cheaper that does the same thing. That is where the looking cool charging by your A/V equipment comes in...
Currently I am rocking a BlackBerry Tour with Verizon...this is an Android forum...that means I need help.
I'm looking to move into an Android phone and the Nexus One looks like it may be the phone for me, but I was hoping to get some thoughts and persuasion from the current Nexus One owners. I wanted to wait a bit until you guys had them in hand for a while to get real opinions after some of the excitement has worn off. I am not overly concerned regarding the 3G connectivity issues as I will be picking up a phone on Verizon and obviously since it's not out yet there may not even be any.
Please let me know your thoughts on:
-the trackball
-the battery life
Any other information that you would like to provide would be greatly appreciated. Please feel free to be as persuasive in either direction as you'd like as I am looking for subjective opinions. I look forward to hearing all of your input.
Thanks in advance,
eipee73
