Figured I'd register after google sent me to this thread - nothing worked, till I did this.. scary stuff!
talk about a design flaw...
Glad it worked for you. Yeah and Sprint and Samsung still have no idea of this method of repair, go figure...
I solved my problem the other day. Look in the USB port on the phone and there is a flat part that should be in the middle so it goes inside the usb plug. Mine was bent and was missing the plug but when I bent it back with a little pocket knife it has been working flawlessly ever since!!
You are so welcome!I registered JUST to say thanks for suggesting this. Nothing else worked for me until I tried it.
Thanks!
Thanks again !!Thank you, I too registered just to say "thanks".
I kept cursing my 3yr old laptop's USB port & did what not to make it work.
Now I realize that I was the one who screwed the usb port on my Nexus S by using a mobile charger whose cable kept flipping out while in my pocket.
God is in the detailsThanks again !!
Thanks!
thank you!same here. i tried a number of different suggested fixes and nothing worked until i came upon your suggestion. a little hesitant at first and worried i would mess up the hardware. but i figured its not working anyways, whats the risk.
It worked!!thank you!
Put another one on the list! A pocket knife, 60 seconds and a gallon of sweat and my phone is fixed! Thank you very much.![]()
